[Proj] PROJ.4: pj_transform parameters
Mikael Rittri Mikael.Rittri at carmenta.com
Thu Oct 4 10:50:22 PDT 2012
I think you must add a final slash after 4326 to make that link work.
Another site you could look at is <http://www.epsg-registry.org> http://www.epsg-registry.org
The +init usually works, but when the underlying datum isn't
WGS84, you will not always get the best possible accuracy.
I believe the default implementation of OSGB36 isn't
very good, for example (it may have improved since
the last time I looked, though).
For ED50, I don't know any implementation that is good in
all of Europe/Middle East. The default has about 10 - 15 m
accuracy. If one needs higher accuracy, one must
choose an implementation that is tailor-made for a
smaller area, say Spain or some part of the North Sea.
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
4 okt 2012 kl. 19:07 skrev "Doanh Hoang" <doanh.hoang at mud-maps.com<mailto:doanh.hoang at mud-maps.com>>:
Hi David.
Thank you for quick support !
Is it right that for another datums (for example : NAD27, NAD83, OSGB, ED 50, etc,...) we can do transformation with only just simple initialization
like projPJ src= pj_init_plus( "+init=epsg:4326"); (I mean that we use only +init parameter)
Clicking on <http://spatialreference.org/ref/epsg/4326> http://spatialreference.org/ref/epsg/4326 I get :  " Not found, /ref/epsg/4326. "
Doanh
On 4 October 2012 23:48, nicolas david <<mailto:ericnico.david at gmail.com>ericnico.david at gmail.com<mailto:ericnico.david at gmail.com>> wrote:
Hi
On our proj4 installation you should have a directory call "nad". This directory have some dictionnary of projection that could be used to define projection parameters. For exemple with the lat/long wgs84 projection you could use
see <http://spatialreference.org/ref/epsg/4326> http://spatialreference.org/ref/epsg/4326 for searching your projection code.
Take care of setting the PROJ_LIB environnement variable to the correct path for your projection directory.
Nicolas
2012/10/4 Doanh Hoang <<mailto:doanh.hoang at mud-maps.com>doanh.hoang at mud-maps.com<mailto:doanh.hoang at mud-maps.com>>
Hi all
Im developer and this is the first time I touch PROJ.4 . And I have following problem , please anyone can give me an advice:
In my project I need to do transformation from datums  (US, North America, UK, South Africa, New Zealand) to WGS84.
After having a look at defintion of pj_transform  (function to do datums transformation on PROJ.4). I have seen that there are so many input parameters.
For example : following code that I found in internet :
    projPJ src= pj_init_plus("+proj=tmerc +lat_0=38N +lon_0=128E +ellps=bessel +x_0=400000 +y_0=600000 +k=0.9999 +towgs84=-146.43,507.89,681.46");
    projPJ dst= pj_init_plus("+proj=latlong +datum=WGS84 +ellps=WGS84");
    double x,y,z;
    x=100;
    y=100;
    z=100;
    pj_transform(src,dst,1,1,&x,&y,NULL);
params for initionlization of datums
+proj=merc +ellps=clrk66 +lat_ts=33
+proj=latlong +ellps=clrk66
There are so many geospatial knowledge neccessary to understand these parameter.
Im developer and I know just only the simple name of datums(WGS84, NAD27, NAD83, etc,..) and coordinates of points,
With them how I can make transformation between different datums ? Where I can get input parameters and define correct geospatial input parameters.
I very need your help. Thanks a lot.
Hoang Doanh
Proj mailing list
<mailto:Proj at lists.maptools.org>Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
<http://lists.maptools.org/mailman/listinfo/proj>http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20121004/4cf3908d/attachment.html>
