[Proj] GeographicLib geoid calculations
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Oct 17 03:29:35 PDT 2012
Charles Karney wrote:
> GeographicLib uses 2 bytes per grid point to store the data (vs 4 bytes
> per grid point for most other implementation) and, by default, does not
> read the entire table into memory.
While not as polished as the very impressive GeographicLib, I thought it
was worth pointing out that an implementation I wrote a couple of years
ago in C has similar properties (2 bytes per grid point, and
user-specifiable how much of the grid to load into memory). It uses the
cubic convolution interpolation method proposed by Keys in 1981. Some
details here:
<https://haptimap.ee.qub.ac.uk/doc/group__standalone__gps.html>
(look at the egm96_* functions) and source code as well as binary grid
file available here:
<https://haptimap.ee.qub.ac.uk/viewvc/haptimap/trunk/plugins/>
The software may be distributed under the LGPL license, although I have
to admit this isn't at all clear from the above links...
> (Incidentally, GeographlicLib lets you work directly with the spherical
> harmonic expansions of the geoid models using the Gravity class.  So you
> can construct grids for any of EGM84, EGM96, or EGM2008 at any
> resolution.)
Again, not so elegant (requires manual pre-processing with no nice API,
but maybe still useful for an embedded application) - grids of any size
at various resolutions may be created using the software here (slightly
modified version of C code by D. Ineiv from 2006):
<https://haptimap.ee.qub.ac.uk/viewvc/haptimap/trunk/external/egm96/>
Just in case it is useful to anybody!
Best regards,
Paul
