[Proj] GeographicLib geoid calculations
support.mn at elisanet.fi support.mn at elisanet.fi
Thu Oct 18 02:09:27 PDT 2012
Paul,
it says:
"egm96.c 	 997 	 22 months 	 paul 	 Improved documentation for "standalone" UTM and EGM96 conversion functions
egm96.dat 	 466 	 2 years 	 paul 	 Add WGS84 --> EGM96 conversion functionality. Not well tested yet. "
"NOT WELL TESTED YET!"
regards: Janne.
Paul Kelly [paul-grass at stjohnspoint.co.uk] kirjoitti:
> Charles Karney wrote:
> > GeographicLib uses 2 bytes per grid point to store the data (vs 4 bytes
> > per grid point for most other implementation) and, by default, does not
> > read the entire table into memory.
> While not as polished as the very impressive GeographicLib, I thought it
> was worth pointing out that an implementation I wrote a couple of years
> ago in C has similar properties (2 bytes per grid point, and
> user-specifiable how much of the grid to load into memory). It uses the
> cubic convolution interpolation method proposed by Keys in 1981. Some
> details here:
> <https://haptimap.ee.qub.ac.uk/doc/group__standalone__gps.html>
> (look at the egm96_* functions) and source code as well as binary grid
> file available here:
> <https://haptimap.ee.qub.ac.uk/viewvc/haptimap/trunk/plugins/>
> The software may be distributed under the LGPL license, although I have
> to admit this isn't at all clear from the above links...
> > (Incidentally, GeographlicLib lets you work directly with the spherical
> > harmonic expansions of the geoid models using the Gravity class.  So you
> > can construct grids for any of EGM84, EGM96, or EGM2008 at any
> > resolution.)
> Again, not so elegant (requires manual pre-processing with no nice API,
> but maybe still useful for an embedded application) - grids of any size
> at various resolutions may be created using the software here (slightly
> modified version of C code by D. Ineiv from 2006):
> <https://haptimap.ee.qub.ac.uk/viewvc/haptimap/trunk/external/egm96/>
> Just in case it is useful to anybody!
> Best regards,
> Paul
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
