[Proj] Programmatically obtaining the domain of a projection
Phil Elson pelson.pub at gmail.com
Mon Apr 22 08:23:00 PDT 2013
I've got a case where I would like to identify the domain of a projection
programmatically. Take the geos projection for example:
$> invproj +proj=geos +h=35785831 +units=m
5.3e6 0
68d48'11.267"E    0dN
5.4e6 0
74d56'57.772"E    0dN
5.5e6 0
$> invproj +proj=geos +h=50000000 +units=m
5.5e6 0
69d42'46.646"E    0dN
5.6e6
74d40'19.703"E    0dN
5.7e6
Are the mathematical limits of Proj4 projections generally available (the C
interface is fine), or is using a numerical method the only way to
calculate the domain?
Notes:
 * There are some domains/bounds available on spatialreference.org (e.g.,
http://spatialreference.org/ref/epsg/4277/) but they are not exhaustive,
are transformed to WGS84 and have presumably been calculated manually.
 * I've had a quick look at PJ_geos to see if this particular example has a
simple solution (and indeed grepped for "limits", "bounds", and "range" in
the whole proj.4 source) without much luck.
 * I've already got a programmatic solution to this, I'm really looking to
find out if there is a more elegant mathematical answer to my problem.
Many thanks in advance,
Phil
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130422/4aad7e61/attachment.html>
