[Proj] Lambert projection with one or two standard parallels and proj4
Linton Corbet lcorbet at gmail.com
Thu Apr 25 00:51:47 PDT 2013
Hello all,
I'm sure there is a gap in my understanding, but I haven't been able to
identify where it is, nor how to fill it. My issue is this:
I'm transforming lon lat coordinates into a lambert conformal conic
projection.
The lambert projection uses a single standard parallel 46.244 and the
central meridian is 17.0. And it's on a sphere, but that's not particularly
relevant here. I am using packages that use the proj4 library.
I test the transformation using linux tool cs2cs as follows:
echo "15.220483 48.437298" | cs2cs +proj=lonlat +to +proj=lcc
+lat_1=46.244 +lat_0=46.244 +lon_0=17. +a=6367470 +b=6367470 +ellps=sphere
+datum=WGS84
-131346.80 245318.16
I also understand that the one-standard parallel form is the same as the
two-standard parallel form if the two standard parallels are the same. It
is more convenient for me to give all parallels in my scripts - let proj do
the work. So I also test with:
echo "15.220483 48.437298" | cs2cs +proj=lonlat +to +proj=lcc +lat_1=46.244
+lat_2=46.244 +lat_0=46.244 +lon_0=17. +a=6367470 +b=6367470 +ellps=sphere
+datum=WGS84
-131290.66 245281.34
yet I get different results. Any ideas as to why?
And at very least, what am I doing wrong and which approach should I use?
Kind regards,
Linton Corbet
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130425/b61eb65b/attachment.html>
