[Proj] Lambert projection with one or two standard parallels and proj4
Charles Karney charles.karney at sri.com
Thu Apr 25 02:45:19 PDT 2013
The default values of lat_1 and lat_2 are 33 and 45, so in your first
example you had +lat_1=46.244 +lat_2=45 which is not what you intended.
The second example does what you wanted.
   --Charles
On 04/25/2013 03:51 AM, Linton Corbet wrote:
> Hello all,
> I'm sure there is a gap in my understanding, but I haven't been able to
> identify where it is, nor how to fill it. My issue is this:
> I'm transforming lon lat coordinates into a lambert conformal conic
> projection.
> The lambert projection uses a single standard parallel 46.244 and the
> central meridian is 17.0. And it's on a sphere, but that's not
> particularly relevant here. I am using packages that use the proj4 library.
> I test the transformation using linux tool cs2cs as follows:
> echo "15.220483 48.437298" | cs2cs +proj=lonlat +to +proj=lcc
> +lat_1=46.244 +lat_0=46.244 +lon_0=17. +a=6367470 +b=6367470
> +ellps=sphere +datum=WGS84
> -131346.80 245318.16
> I also understand that the one-standard parallel form is the same as the
> two-standard parallel form if the two standard parallels are the same.
> It is more convenient for me to give all parallels in my scripts - let
> proj do the work. So I also test with:
> +lat_1=46.244 +lat_2=46.244 +lat_0=46.244 +lon_0=17. +a=6367470
> +b=6367470 +ellps=sphere +datum=WGS84
> -131290.66 245281.34
> yet I get different results. Any ideas as to why?
> And at very least, what am I doing wrong and which approach should I use?
> Kind regards,
> Linton Corbet
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
