[Proj] Datum shift not working
Even Rouault even.rouault at spatialys.com
Sat Aug 30 01:40:22 PDT 2014
Paul,
as far as I know, the proj utility doesn't do datum shifts. You should rather
use cs2cs (and as per
http://trac.osgeo.org/proj/wiki/FAQ#WhydoIgetdifferentresultswith4.5.0and4.6.0,
"PROJ.4 will now only apply a datum shift if both the source and destination
coordinate system have valid datum shift information") :
$ cs2cs +proj=longlat +ellps=clrk80 +towgs84=0,0,0 +no_defs +to +proj=utm
+zone=40 +ellps=clrk80
+towgs84=-180.624,-225.516,173.919,-0.81,-1.898,8.336,16.7101 +units=m
+no_defs -f "%.6f"
59.28632619 24.27334106
731801.730465	2685882.517256 82.812593
+zone=40 +ellps=clrk80 +units=m +no_defs -f "%.6f"
732098.167370	2686171.824604 0.000000
Even
Le samedi 30 août 2014 10:26:28, Paul Boettinger a écrit :
> Hello,
> i want to do a transformation with the EPSG Code 3440
> In my epsg file 3440 references the following parameters:
> +proj=utm +zone=40 +ellps=clrk80
> +no_defs
> Executing proj 4.8.0_0 from the MacPorts Repository on OSX 10.9.4 makes no
> differences using the transformation with or without the datum shift. Any
> help welcome,
> Paul
> proj +proj=utm +zone=40 +ellps=clrk80
> +no_defs -f "%.6f" 59.28632619 24.27334106
> proj +proj=utm +zone=40 +ellps=clrk80 +units=m +no_defs -f "%.6f"
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
http://www.spatialys.com
