[Proj] Datum shift not working
Paul Boettinger pboe at gmx.de
Sat Aug 30 02:00:30 PDT 2014
Hi Even,
thank you very much for the fast response.
Paul
Am 30.08.2014 um 12:40 schrieb Even Rouault <even.rouault at spatialys.com>:
> Paul,
> as far as I know, the proj utility doesn't do datum shifts. You should rather
> use cs2cs (and as per
> http://trac.osgeo.org/proj/wiki/FAQ#WhydoIgetdifferentresultswith4.5.0and4.6.0,
> "PROJ.4 will now only apply a datum shift if both the source and destination
> coordinate system have valid datum shift information") :
> $ cs2cs +proj=longlat +ellps=clrk80 +towgs84=0,0,0 +no_defs +to +proj=utm
> +zone=40 +ellps=clrk80
> +towgs84=-180.624,-225.516,173.919,-0.81,-1.898,8.336,16.7101 +units=m
> +no_defs -f "%.6f"
> 59.28632619 24.27334106
> 731801.730465	2685882.517256 82.812593
> +zone=40 +ellps=clrk80 +units=m +no_defs -f "%.6f"
> 732098.167370	2686171.824604 0.000000
> Even
> Le samedi 30 août 2014 10:26:28, Paul Boettinger a écrit :
>> Hello,
>> i want to do a transformation with the EPSG Code 3440
>> In my epsg file 3440 references the following parameters:
>> +proj=utm +zone=40 +ellps=clrk80
>> +no_defs
>> Executing proj 4.8.0_0 from the MacPorts Repository on OSX 10.9.4 makes no
>> differences using the transformation with or without the datum shift. Any
>> help welcome,
>> Paul
>> proj +proj=utm +zone=40 +ellps=clrk80
>> +no_defs -f "%.6f" 59.28632619 24.27334106
>> proj +proj=utm +zone=40 +ellps=clrk80 +units=m +no_defs -f "%.6f"
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Spatialys - Geospatial professional services
> http://www.spatialys.com
