[Proj] NAD_1983_To_WGS_1984_5
Roger Bivand Roger.Bivand at nhh.no
Sat Aug 30 05:04:44 PDT 2014
I'm aware of Frank's reply:
http://lists.maptools.org/pipermail/proj/2008-September/003833.html
but would value clarification of why this happens (further details on:
https://stat.ethz.ch/pipermail/r-sig-geo/2014-August/021611.html
from WGS84 geographical coordinates to NAD27 via WGS84_5).
(code attached to get around line breaks)
The first test using cs2cs is wrong because it doesn't use +towgs84= to
use *_5:
(the test is against benchmark coordinates)
The works in the first sub-step (geographical to WGS84_5 State Plane):
So locs.step1 are OK, but the next step gets the same errors as ignoring
*_5
Turning on -v shows:
cs2cs -v -f "%16.9f" +proj=lcc +lat_1=38.43333333333333
+lat_2=37.06666666666667 +lat_0=36.5 +lon_0=-120.5 +x_0=2000000.0
+y_0=500000.0 +ellps=GRS80 +datum=NAD83 +units=us-ft +no_defs
+towgs84=-0.991,1.9072,0.5129,0.025789908,0.0096501,0.0116599,0.0 +to
+init=epsg:26743 < locs.step1
# ---- From Coordinate System ----
#Lambert Conformal Conic
#	Conic, Sph&Ell
#	lat_1= and lat_2= or lat_0
# +proj=lcc +lat_1=38.43333333333333 +lat_2=37.06666666666667 +lat_0=36.5
# +lon_0=-120.5 +x_0=2000000.0 +y_0=500000.0 +ellps=GRS80 +datum=NAD83
# +units=us-ft +no_defs
# +towgs84=-0.991,1.9072,0.5129,0.025789908,0.0096501,0.0116599,0.0
#--- following specified but NOT used
# +ellps=GRS80 +towgs84=0,0,0
# ---- To Coordinate System ----
#	Conic, Sph&Ell
# +init=epsg:26743 +proj=lcc +lat_1=38.43333333333333
# +lat_2=37.06666666666667 +lat_0=36.5 +lon_0=-120.5
+x_0=609601.2192024384
# +y_0=0 +datum=NAD27 +units=us-ft +no_defs +ellps=clrk66
# +nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat
Puzzled,
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140830/aecdbe47/attachment.txt>
