[Proj] Mapserver Projection Issue
Richard Greenwood richard.greenwood at gmail.com
Thu Jan 2 10:54:56 PST 2014
On Thu, Jan 2, 2014 at 11:30 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 1/2/2014 10:21 AM, Richard Greenwood wrote:
> > Steve,
> > Replying off list, for what it's worth I'm seeing the same issue with
> > your data on Ubutu 12.04, Proj 4.8, mapserv 6.2.1 built from source. I
> > rarely use web mercator in my work so I have limited experience with it
> > and limited data. I notice that ogrinfo on your world_disolve reports:
> >     Extent: (-180.000015, -90.000015) - (179.999985, 83.633385)
> Hmmm, these values might be a problem: -180.000015, -90.000015
> I'll load that into postgis and see if I can fiddle with these and if
> that makes a difference.
> Thank you for your time and effort.
> > Have you tested with any other data?
> I got similar results using the Natural Earth data.
Did you see my second reply (which actually was off list)? I think the
problem is in the data because with just the USA & Canada it rendered
correctly but adding Russia and Greenland caused the rendering issues to
reappear.
Keep us posted.
Rich
> On Thu, Jan 2, 2014 at 7:43 AM, Stephen Woodbridge
> > <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> >     On 1/2/2014 9:13 AM, Richard Greenwood wrote:
> >      > Are you sure that it's finding and using the correct epsg file?
> You
> >      > could specify the full path to an epsg file in either the mapfile
> >     or the
> >      > apache conf, or paste the proj parameters into the PROJ block in
> the
> >      > mapfile and do away wit the epsg file completely.
> >     It is a clean new system with only the Ubuntu package installed. I
> added
> >     900913 to the /usr/share/proj/epsg file. I also just modified the
> >     mapfile and entered the projection parameters in it directly as you
> >     suggested with the same result.
> >     If you want to try this, download
> http://imaptools.com:8080/dl/world.tbz
> >     It resides in directory /u/data/ on my system so you would need to
> >     adjust the paths appropriately.
> >     I've now spent 3 days fussing with this and trying to debug it. I
> >     suppose the next thing to try is to build proj4-4.6.0 on the Ubuntu
> >     system and see if that resolves the issue.
> >     Thanks,
> >         -Steve
> >     Here is the mapfile:
> >     MAP
> >         NAME "World_WMS"
> >         STATUS ON
> >         SIZE 800 800
> >         #EXTENT -180 -90 180 90
> >         EXTENT -20037508.34 -20037508.34  20037508.34  20037508.34
> >         UNITS DD
> >         SHAPEPATH "/u/data/world/"
> >         IMAGECOLOR "#80B1D3"
> >         FONTSET "/u/data/world/fontset.txt"
> >         IMAGETYPE "agg_qn"
> >         MAXSIZE 4000
> >         CONFIG MS_ERRORFILE "stderr"
> >         CONFIG ON_MISSING_DATA "IGNORE"
> >         #DEBUG 10
> >         OUTPUTFORMAT
> >           NAME "agg_qn"
> >           DRIVER "AGG/PNG"
> >           EXTENSION "png"
> >           MIMETYPE "image/png"
> >           IMAGEMODE RGB
> >           FORMATOPTION "INTERLACE=false"
> >           FORMATOPTION "QUANTIZE_NEW=ON"
> >           FORMATOPTION "QUANTIZE_FORCE=ON"
> >           FORMATOPTION "QUANTIZE_DITHER=OFF"
> >           FORMATOPTION "QUANTIZE_COLORS=256"
> >         END
> >         OUTPUTFORMAT
> >           NAME aggpng24
> >           DRIVER AGG/PNG
> >           IMAGEMODE RGB
> >           EXTENSION "png"
> >         END
> >         WEB
> >           METADATA
> >             "labelcache_map_edge_buffer" "-20"
> >             "ows_title" "World_WMS"
> >             "ows_onlineresource"
> http://imaptools.com:8080/cgi-bin/mapserv?map=/u/data/world/world.map&"
> >             "ows_srs" "EPSG:4326 EPSG:900913 EPSG:4269 EPSG:3857"
> >             "ows_feature_info_mime_type" "text/html"
> >             "ows_enable_request" "GetMap"
> >             "ows_contactperson"     "Stephen Woodbridge"
> >             "ows_contactorganization" "iMaptools.com"
> >             "ows_contactposition"   "Owner"
> >             "ows_contactelectronicmailaddress" "info at imaptools.com
> >     <mailto:info at imaptools.com>"
> >             "ows_attribution_title"   "Data copyright by LeadDog
> >     Consulting."
> >           END
> >         END
> >     #  PROJECTION "init=epsg:4326" END
> >         PROJECTION "+proj=lcc +lat_1=17.5 +lat_2=29.5 +lat_0=12
> +lon_0=-102
> >     +x_0=2500000 +y_0=0 +datum=WGS84 +units=m +no_defs" END
> >         LAYER
> >           STATUS DEFAULT
> >           TYPE POLYGON
> >           FEATURE
> >               POINTS -180 -90 -180 90 180 90 180 -90 -180 -90 END
> >           END
> >           CLASS
> >             STYLE
> >               COLOR "#80B1D3"
> >             END
> >           END
> >         END
> >         LAYER
> >           NAME "World"
> >           GROUP "cb"
> >           METADATA
> >             ows_title "World"
> >             ows_group_title "Land Mass"
> >           END
> >           STATUS ON
> >           TYPE POLYGON
> >           DATA "world_dissolve"
> >           CLASS
> >             STYLE
> >               COLOR "#CACACA"
> >               OUTLINECOLOR "#888888"
> >             END
> >           END
> >         END
> >     END
> >      > Rich
> >      > On Wed, Jan 1, 2014 at 9:47 AM, Stephen Woodbridge
> >     <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>
> >     wrote:
> >      >     Hi All,
> >      >     I'm trying to run down a mapserver projection issue that is
> >     starting to
> >      >     look like it might be the version of proj4. Sorry for the
> >     cross posting.
> >      >     Situation:
> >      >     I'm upgrading my server from Debian Lenny to Ubuntu 12.04 LTS
> >     and world
> >      >     maps on the Ubuntu system projected to Spherical Mercator are
> >     messed up
> >      >     and worked fine on Debian. I get the same issue using
> >     mapserver 6.2.1 or
> >      >     5.6.8 and the big difference other than the OS and packages
> >     is that
> >      >     Ubuntu is using proj4-4.8.0 and the older Debian system is
> using
> >      >     proj4-4.6.0
> >      >     Is this a known issue? I can make the data mapfile available
> >     if that
> >      >     helps.
> >      >     System details below.
> >      >     Any help would be appreciated.
> >      >     Thanks,
> >      >         -Steve
> >      >     Ubuntu system:
> http://imaptools.com:8080/cgi-bin/mapserv?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
> >      >     /u/www/cgi-bin/mapserv -v
> >      >     MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> >     SUPPORTS=PROJ
> >      >     SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> >      >     SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI
> >     SUPPORTS=WMS_SERVER
> >      >     SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> >      >     SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> >      >     SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR
> >      >     INPUT=GDAL INPUT=SHAPEFILE
> >      >     libproj-dev/precise uptodate 4.8.0-3~precise2
> >      >     libproj0/precise uptodate 4.8.0-3~precise2
> >      >     proj-bin/precise uptodate 4.8.0-3~precise2
> >      >     proj-data/precise uptodate 4.8.0-3~precise2
> >      >     # Spherical Mercator projection
> >      >     <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +lon_0=0.0
> >      >     +x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null
> >     +no_defs  <>
> >      >     cgi-mapserver/precise uptodate 6.2.1-2~precise3
> >      >     libmapserver/precise uptodate 6.2.1-2~precise3
> >      >     mapserver-bin/precise uptodate 6.2.1-2~precise3
> >      >     Linux mappy 3.8.0-33-generic #48~precise1-Ubuntu SMP Thu Oct
> >     24 16:28:06
> >      >     UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
> >      >     I also get the same result from:
> >      >     /u/www/cgi-bin/mapserv-56 -v
> >      >     MapServer version 5.6.8 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> >     OUTPUT=WBMP
> >      >     OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> >     SUPPORTS=ICONV
> >      >     SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> >      >     SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
> >     INPUT=GDAL
> >      >     INPUT=SHAPEFILE
> >      >     which was built from source also using the libproj packages
> >     above.
> >      >     Debian Lenny system:
> http://gis.imaptools.com/cgi-bin/mapserv-6.2?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
> >      >     proj/lenny uptodate 4.6.0-2
> >      >     # Spherical Mercator - Google
> +lon_0=0.0
> >     +no_defs  <>
> >      >     Linux gis.leaddog.com <http://gis.leaddog.com>
> >     <http://gis.leaddog.com> 2.6.32-042stab081.8
> >      >     #1 SMP Wed Oct 23 16:32:28 MSK
> >      >     2013 x86_64 GNU/Linux
> >      >     I built mapserver from source and I also get the same result
> from
> >      >     mapserver-5.6.8 built from source.
> >      >     _______________________________________________
> >      >     Proj mailing list
> >      > Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
> >     <mailto:Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>>
> >      > http://lists.maptools.org/mailman/listinfo/proj
> >      > Richard Greenwood
> >      > richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>
> >     <mailto:richard.greenwood at gmail.com>>
> >      > www.greenwoodmap.com <http://www.greenwoodmap.com>
> >      > Proj mailing list
> >     Proj mailing list
> > Richard Greenwood
> > Proj mailing list
> Proj mailing list
Richard Greenwood
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20140102/1bf99b2d/attachment.html>
