[Proj] Mapserver Projection Issue
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jan 2 13:28:04 PST 2014
Ok, I fix this by loading the shapefile into postgis and running this query:
  update world set geom=st_intersection(geom,
st_transform(st_setsrid('POLYGON((-20037508.34 -20037508.34,-20037508.34
20037508.34,20037508.34 20037508.34,20037508.34
-20037508.34,-20037508.34 -20037508.34))'::geometry, 3857), 4326)) where
gid in (220,222,235);
It turns out that these three polygons had extents that exceeded lat
and/or long maximum extents for spherical Mercator:
world=# select gid, st_astext(geom) from ( select gid,
st_astext(st_extent(geom)
  gid |
  220 | POLYGON((-180.000014999871 -90.0000149996579,-180.000014999871
-60.492514 ...
  222 | POLYGON((-180.000014999871 -21.0273150004093,-180.000014999871
-12.457514 ...
  235 | POLYGON((-180.000014999871 41.1888849995916,-180.000014999871
81.86168499 ...
(3 rows)
It is not clear why this worked on 4.6.0 and not on 4.8.0 !!!
http://imaptools.com:8080/cgi-bin/mapserv?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
Works after intersecting with the max bbox for spherical Mercator and
dumping it back to a shapefile.
Thanks to Richard for his help debugging this.
-Steve
On 1/2/2014 1:54 PM, Richard Greenwood wrote:
> On Thu, Jan 2, 2014 at 11:30 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 1/2/2014 10:21 AM, Richard Greenwood wrote:
>      > Steve,
>      > Replying off list, for what it's worth I'm seeing the same issue with
>      > your data on Ubutu 12.04, Proj 4.8, mapserv 6.2.1 built from
>     source. I
>      > rarely use web mercator in my work so I have limited experience
>     with it
>      > and limited data. I notice that ogrinfo on your world_disolve
>     reports:
>      >     Extent: (-180.000015, -90.000015) - (179.999985, 83.633385)
>     Hmmm, these values might be a problem: -180.000015, -90.000015
>     I'll load that into postgis and see if I can fiddle with these and if
>     that makes a difference.
>     Thank you for your time and effort.
>      > Have you tested with any other data?
>     I got similar results using the Natural Earth data.
> Did you see my second reply (which actually was off list)? I think the
> problem is in the data because with just the USA & Canada it rendered
> correctly but adding Russia and Greenland caused the rendering issues to
> reappear.
> Keep us posted.
> Rich
>  > On Thu, Jan 2, 2014 at 7:43 AM, Stephen Woodbridge
>     <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>
>     wrote:
>      >     On 1/2/2014 9:13 AM, Richard Greenwood wrote:
>      >      > Are you sure that it's finding and using the correct epsg
>     file? You
>      >      > could specify the full path to an epsg file in either the
>     mapfile
>      >     or the
>      >      > apache conf, or paste the proj parameters into the PROJ
>     block in the
>      >      > mapfile and do away wit the epsg file completely.
>      >     It is a clean new system with only the Ubuntu package
>     installed. I added
>      >     900913 to the /usr/share/proj/epsg file. I also just modified the
>      >     mapfile and entered the projection parameters in it directly
>     as you
>      >     suggested with the same result.
>      >     If you want to try this, download
>     http://imaptools.com:8080/dl/world.tbz
>      >     It resides in directory /u/data/ on my system so you would
>     need to
>      >     adjust the paths appropriately.
>      >     I've now spent 3 days fussing with this and trying to debug it. I
>      >     suppose the next thing to try is to build proj4-4.6.0 on the
>     Ubuntu
>      >     system and see if that resolves the issue.
>      >     Thanks,
>      >         -Steve
>      >     Here is the mapfile:
>      >     MAP
>      >         NAME "World_WMS"
>      >         STATUS ON
>      >         SIZE 800 800
>      >         #EXTENT -180 -90 180 90
>      >         EXTENT -20037508.34 -20037508.34  20037508.34  20037508.34
>      >         UNITS DD
>      >         SHAPEPATH "/u/data/world/"
>      >         IMAGECOLOR "#80B1D3"
>      >         FONTSET "/u/data/world/fontset.txt"
>      >         IMAGETYPE "agg_qn"
>      >         MAXSIZE 4000
>      >         CONFIG MS_ERRORFILE "stderr"
>      >         CONFIG ON_MISSING_DATA "IGNORE"
>      >         #DEBUG 10
>      >         OUTPUTFORMAT
>      >           NAME "agg_qn"
>      >           DRIVER "AGG/PNG"
>      >           EXTENSION "png"
>      >           MIMETYPE "image/png"
>      >           IMAGEMODE RGB
>      >           FORMATOPTION "INTERLACE=false"
>      >           FORMATOPTION "QUANTIZE_NEW=ON"
>      >           FORMATOPTION "QUANTIZE_FORCE=ON"
>      >           FORMATOPTION "QUANTIZE_DITHER=OFF"
>      >           FORMATOPTION "QUANTIZE_COLORS=256"
>      >         END
>      >         OUTPUTFORMAT
>      >           NAME aggpng24
>      >           DRIVER AGG/PNG
>      >           IMAGEMODE RGB
>      >           EXTENSION "png"
>      >         END
>      >         WEB
>      >           METADATA
>      >             "labelcache_map_edge_buffer" "-20"
>      >             "ows_title" "World_WMS"
>      >             "ows_onlineresource"
>     "http://imaptools.com:8080/cgi-bin/mapserv?map=/u/data/world/world.map&"
>      >             "ows_srs" "EPSG:4326 EPSG:900913 EPSG:4269 EPSG:3857"
>      >             "ows_feature_info_mime_type" "text/html"
>      >             "ows_enable_request" "GetMap"
>      >             "ows_contactperson"     "Stephen Woodbridge"
>      >             "ows_contactorganization" "iMaptools.com"
>      >             "ows_contactposition"   "Owner"
>      >             "ows_contactelectronicmailaddress"
>     "info at imaptools.com <mailto:info at imaptools.com>
>      >     <mailto:info at imaptools.com <mailto:info at imaptools.com>>"
>      >             "ows_attribution_title"   "Data copyright by LeadDog
>      >     Consulting."
>      >           END
>      >         END
>      >     #  PROJECTION "init=epsg:4326" END
>      >         PROJECTION "+proj=lcc +lat_1=17.5 +lat_2=29.5 +lat_0=12
>     +lon_0=-102
>      >     +x_0=2500000 +y_0=0 +datum=WGS84 +units=m +no_defs" END
>      >         LAYER
>      >           STATUS DEFAULT
>      >           TYPE POLYGON
>      >           FEATURE
>      >               POINTS -180 -90 -180 90 180 90 180 -90 -180 -90 END
>      >           END
>      >           CLASS
>      >             STYLE
>      >               COLOR "#80B1D3"
>      >             END
>      >           END
>      >         END
>      >         LAYER
>      >           NAME "World"
>      >           GROUP "cb"
>      >           METADATA
>      >             ows_title "World"
>      >             ows_group_title "Land Mass"
>      >           END
>      >           STATUS ON
>      >           TYPE POLYGON
>      >           DATA "world_dissolve"
>      >           CLASS
>      >             STYLE
>      >               COLOR "#CACACA"
>      >               OUTLINECOLOR "#888888"
>      >             END
>      >           END
>      >         END
>      >     END
>      >      > Rich
>      >      > On Wed, Jan 1, 2014 at 9:47 AM, Stephen Woodbridge
>     <mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com
>     <mailto:woodbri at swoodbridge.com>>>>
>      >     wrote:
>      >      >     Hi All,
>      >      >     I'm trying to run down a mapserver projection issue
>     that is
>      >     starting to
>      >      >     look like it might be the version of proj4. Sorry for the
>      >     cross posting.
>      >      >     Situation:
>      >      >     I'm upgrading my server from Debian Lenny to Ubuntu
>     12.04 LTS
>      >     and world
>      >      >     maps on the Ubuntu system projected to Spherical
>     Mercator are
>      >     messed up
>      >      >     and worked fine on Debian. I get the same issue using
>      >     mapserver 6.2.1 or
>      >      >     5.6.8 and the big difference other than the OS and
>     packages
>      >     is that
>      >      >     Ubuntu is using proj4-4.8.0 and the older Debian
>     system is using
>      >      >     proj4-4.6.0
>      >      >     Is this a known issue? I can make the data mapfile
>     available
>      >     if that
>      >      >     helps.
>      >      >     System details below.
>      >      >     Any help would be appreciated.
>      >      >     Thanks,
>      >      >         -Steve
>      >      >     Ubuntu system:
>      >      >     /u/www/cgi-bin/mapserv -v
>      >      >     MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>      >     SUPPORTS=PROJ
>      >      >     SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>      >      >     SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI
>      >     SUPPORTS=WMS_SERVER
>      >      >     SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>     SUPPORTS=WFS_CLIENT
>      >      >     SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>      >      >     SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
>     INPUT=POSTGIS INPUT=OGR
>      >      >     INPUT=GDAL INPUT=SHAPEFILE
>      >      >     libproj-dev/precise uptodate 4.8.0-3~precise2
>      >      >     libproj0/precise uptodate 4.8.0-3~precise2
>      >      >     proj-bin/precise uptodate 4.8.0-3~precise2
>      >      >     proj-data/precise uptodate 4.8.0-3~precise2
>      >      >     # Spherical Mercator projection
>      >      >     <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
>     +lon_0=0.0
>      >      >     +x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null
>      >     +no_defs  <>
>      >      >     cgi-mapserver/precise uptodate 6.2.1-2~precise3
>      >      >     libmapserver/precise uptodate 6.2.1-2~precise3
>      >      >     mapserver-bin/precise uptodate 6.2.1-2~precise3
>      >      >     Linux mappy 3.8.0-33-generic #48~precise1-Ubuntu SMP
>     Thu Oct
>      >     24 16:28:06
>      >      >     UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
>      >      >     I also get the same result from:
>      >      >     /u/www/cgi-bin/mapserv-56 -v
>      >      >     MapServer version 5.6.8 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>      >     OUTPUT=WBMP
>      >      >     OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>      >     SUPPORTS=ICONV
>      >      >     SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>      >      >     SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
>      >     INPUT=GDAL
>      >      >     INPUT=SHAPEFILE
>      >      >     which was built from source also using the libproj
>     packages
>      >     above.
>      >      >     Debian Lenny system:
>     http://gis.imaptools.com/cgi-bin/mapserv-6.2?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
>      >      >     proj/lenny uptodate 4.6.0-2
>      >      >     # Spherical Mercator - Google
>     +lon_0=0.0
>      >     +no_defs  <>
>      >      >     Linux gis.leaddog.com <http://gis.leaddog.com>
>      >     <http://gis.leaddog.com> 2.6.32-042stab081.8
>      >      >     #1 SMP Wed Oct 23 16:32:28 MSK
>      >      >     2013 x86_64 GNU/Linux
>      >      >     I built mapserver from source and I also get the same
>     result from
>      >      >     mapserver-5.6.8 built from source.
>      >      >     _______________________________________________
>      >      >     Proj mailing list
>      >      > Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
>     <mailto:Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>>
>     <mailto:Proj at lists.maptools.org> <mailto:Proj at lists.maptools.org
>     <mailto:Proj at lists.maptools.org>>>
>      >      > http://lists.maptools.org/mailman/listinfo/proj
>      >      > Richard Greenwood
>      >      > richard.greenwood at gmail.com
>     <mailto:richard.greenwood at gmail.com>
>     <mailto:richard.greenwood at gmail.com>>
>     <mailto:richard.greenwood at gmail.com>>>
>      >      > www.greenwoodmap.com <http://www.greenwoodmap.com>
>      >      > Proj mailing list
>      >     Proj mailing list
>      > Richard Greenwood
>      > richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>
>      > Proj mailing list
>     Proj mailing list
> Richard Greenwood
> Proj mailing list
