[Proj] Proj 4.9.1RC3 Released
Howard Butler howard at hobu.co
Sat Feb 21 09:31:23 PST 2015
All,
Proj4 4.9.1RC3 is now released for testing. Should no significant issues be identified, this is the last release candidate, and I will motion the MetaCRS list to promote it to final on Wednesday.
Thanks for testing the past two RC's.
Howard
http://download.osgeo.org/proj/proj-4.9.1RC3.tar.gz
> 4.9.1 Release Notes
>  o 4.9.0RC2 release was abandoned because it was not promoted in a
>    timely fashion. Subsequent maintenance of tickets has continued,
>    and a new 4.9.1 release was issued in its place.
>  o Implement inverse solution for Winkel Tripel from Drazan Tutic #250
>  o More CMake configuration tweaks. The CMake configuration is probably
>    not at feature parity with the autotools builds at this point but it
>    is converging #256
>  o Tweak initialization ordering around setlocal which may have caused
>    issues #237
>  o Support out-of-tree autoconf builds more completely #247
>  o Fix NaN handling by geod_inverse and geod_polygon_addedge #251 & #253
>  o Update config.sub and config.guess #257
>  o Adapt Charles Karney's CMake patches for smoother build #258
>  o Define default PROJ_LIB location for CMake compilation #261
>  o Fix Windows compilation on PJ_aitoff.c
>  o Align CMake SOVERSION with autotools #263
>  o Regenerate nad/epsg with GDAL r28536 to avoid precision loss in TOWGS84
>    parameters, e.g. on Amersfoort / RD EPSG:4289 (#260)
