[Proj] Proj 4.9.1RC3 Released
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Feb 21 10:21:06 PST 2015
Works well on Windows.  Thanks Howard!
-jeff
On 2015-02-21 1:31 PM, Howard Butler wrote:
> All,
> Proj4 4.9.1RC3 is now released for testing. Should no significant issues be identified, this is the last release candidate, and I will motion the MetaCRS list to promote it to final on Wednesday.
> Thanks for testing the past two RC's.
> Howard
> http://download.osgeo.org/proj/proj-4.9.1RC3.tar.gz
>> 4.9.1 Release Notes
>>   o 4.9.0RC2 release was abandoned because it was not promoted in a
>>     timely fashion. Subsequent maintenance of tickets has continued,
>>     and a new 4.9.1 release was issued in its place.
>>   o Implement inverse solution for Winkel Tripel from Drazan Tutic #250
>>   o More CMake configuration tweaks. The CMake configuration is probably
>>     not at feature parity with the autotools builds at this point but it
>>     is converging #256
>>   o Tweak initialization ordering around setlocal which may have caused
>>     issues #237
>>   o Support out-of-tree autoconf builds more completely #247
>>   o Fix NaN handling by geod_inverse and geod_polygon_addedge #251 & #253
>>   o Update config.sub and config.guess #257
>>   o Adapt Charles Karney's CMake patches for smoother build #258
>>   o Define default PROJ_LIB location for CMake compilation #261
>>   o Fix Windows compilation on PJ_aitoff.c
>>   o Align CMake SOVERSION with autotools #263
>>   o Regenerate nad/epsg with GDAL r28536 to avoid precision loss in TOWGS84
>>     parameters, e.g. on Amersfoort / RD EPSG:4289 (#260)
