[Proj] Difference in Orthographic projection between Proj4 and Global Mapper
Noel Zinn (cc) ndzinn at comcast.net
Thu Jul 7 12:55:04 PDT 2016
Frederick Pearson, II?  I didn't know that, Cliff, but, after going down the rat holes of innumerable typos in his book "Map Projections: Theory and Applications", I sort of gave up on Pearson.  CRC Press didn't serve him well.  -Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
Sent: Thursday, July 07, 2016 2:28 PM
To: ndzinn at comcast.net ; vanadovv at hetnet.nl ; PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Difference in Orthographic projection between Proj4 and Global Mapper
Noel,
Which then begs the question, why not use the Authalic Latitude function for your spherical equal area projection …
That’s what Pearson tried to do when proposed the idea for the old Bonne projection applications in reproducing 19th century graticules.
Not mathematically equivalent, but that’s what he proposed.
Cliff
Clifford J. Mugnier, CP,CMS,FASPRS
Chief of Geodesy,
Center for GeoInformatics (C4G)
266 ERAD (Research)
3335 PFT  (Academic)
Dept. of Civil & Environmental Engineering
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA  70803
Research  225-578-4578
Academic   225-578-8536
Cell          225-328-8975
From: <proj-bounces at lists.maptools.org> on behalf of "vanadovv at hetnet.nl"
Reply-To: "vanadovv at hetnet.nl", "PROJ.4 and general Projections Discussions"
Date: Thursday, July 7, 2016 at 2:22 PM
To: "PROJ.4 and general Projections Discussions"
The radius of 6370997 is the integer part of the authalic radius of the Clarke 1866 ellipsoid.
The calculated value would be around 6370997.24063266 m.
Greetings,
Oscar van Vlijmen
  ----Origineel Bericht----
  Van : ndzinn at comcast.net
  Datum : 07/07/2016 19:59
  Aan : proj at lists.maptools.org
  Onderwerp : Re: [Proj] Difference in Orthographic projection between Proj4 and Global Mapper
  Hi Huw,
  Given ellipsoidal parameters there are many spherical radii from which to choose.  Wikipedia gives a good summary:
  https://en.wikipedia.org/wiki/Earth_radius
  But where does GCTP’s 6370997 come from?  It’s close to some radii for WGS84, but no cigar.  Is it just a convention?  Anyone know?
  Of course, if you’re mapping on a sphere “closeness” shouldn’t really matter very much.  Consistency should matter more, and, in that sense, a conventional radius would be useful.
  Noel
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160707/f67b06a0/attachment.html>
