[Proj] Difference in Orthographic projection between Proj4 and Global Mapper
Finn, Michael mfinn at usgs.gov
Fri Jul 8 14:09:07 PDT 2016
Hello,
I can confirm the value of the radius used by GCTP if it helps any.
Mike
On Thu, Jul 7, 2016 at 9:00 AM, Ills <mangahair at gmail.com> wrote:
> Thanks for all the replies and suggestions so far,
> After more testing, which shows that we can get identical results in proj4
> as GlobalMapper using a spheroid radius of 6367444.66m. This is the
> midpoint
> of the standard WGS84 semi-major (6378137) and semi-minor axes radii
> (6356752.3).
> This seems to be different from the normal mean earth radius used by GCTP
> (6370997).
> Waiting on a a reply from Blue Marble, loathing to think about all the data
> which could now be wrong and again thanking you all for your time.
> Ills
> http://osgeo-org.1560.x6.nabble.com/Difference-in-Orthographic-projection-between-Proj4-and-Global-Mapper-tp5275097p5275198.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20160708/132c94cb/attachment.html>
