[Proj] Failed to initialize PROJ.4 with "..."
Chris Marsh chris.marsh at usask.ca
Tue Jan 30 15:02:58 PST 2018
To close the loop on this, it was a name conflict with the proj4 that is in
VTK
Details here:
http://vtk.1045678.n5.nabble.com/Don-t-build-vtkproj4-tp5746073p5746269.html
Thanks everyone for their help
Cheers
Chris
On 13 October 2017 at 17:35, Chris Marsh <chris.marsh at usask.ca> wrote:
> I did not build with that option, however I have my build libproj.so in my
> LD_LIBRARY_PATH
> Chris Marsh
> PhD Candidate
> chrismarsh.ca
> 121 Research Drive
> University of Saskatchewan
> On 13 October 2017 at 16:32, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On vendredi 13 octobre 2017 15:56:09 CEST Chris Marsh wrote:
>> > Hi,
>> > I'm using GDAL (and by extension proj.4) to reproject a set of WGS84
>> > coordinates to North America Albers Conic Conformal.
>> > I originally posted this to the GDAL list, however it seems like this
>> may
>> > be entirely a Proj.4 problem.
>> > On all but 1 computer I run my code on, this works as expected. However,
>> > when trying to run on one of Compute Canada's newest machines, I get the
>> > error
>> How did you build GDAL  on that machine, --with-static-proj4 ?
>> If not, the issue is probably that you have libproj.so.XXXX installed,
>> but not
>> libproj.so
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180130/cba53c40/attachment.html>
