[Proj] Converting between true north, grid north, and magnetic north
J Luis jmfluis at gmail.com
Wed Jan 31 03:50:17 PST 2018
Or GMT that even provides an estimate of daily variation.
https://gmt.soest.hawaii.edu/doc/5.4.3/supplements/mgd77/mgd77magref.html
On Tue, Jan 30, 2018 at 9:59 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Be aware that the magnetic field is time varying.  It can change pretty
> quickly near the magnetic poles.
> Yet another source... igrf.py
> https://earthref.org/PmagPy/cookbook/#x1-1190005.2.54
> On Tue, Jan 30, 2018 at 7:03 AM, Charles Karney <charles.karney at sri.com>
> wrote:
>> GeographicLib https://geographiclib.sourceforge.io provides access to
>> several magnetic models via the MagneticField utility.  E.g.,
>>    echo 42.363 -71.006 | MagneticField -t now
>>    -14.67 67.08 20228.0 19569.1 -5121.1 47840.0 51940.7
>> The first number is the current magnetic declination at Boston Logan
>> Airport using the wmm2015 magnetic model.
>> The magnetic models need to be downloaded separately from the
>> GeographicLib library using
>>    geographiclib-get-magnetic
>> On 01/30/18 06:42, Chen Barnoy wrote:
>> > Hi,
>> > Is there a way to convert between grid north, true north and magnetic
>> > north in Proj4 or another library?
>> > Cheers,
>> > Chen
>> > _______________________________________________
>> > Proj mailing list
>> > Proj at lists.maptools.org
>> > http://lists.maptools.org/mailman/listinfo/proj
>> Proj mailing list
> http://schwehr.org
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20180131/4f0ab200/attachment.html>
