[PROJ] About PROJ.6: Radians or Degrees ?
Kristian Evers kreve at sdfe.dk
Tue Apr 2 03:52:25 PDT 2019
> Kristian, perhaps the documentation should explicitly mention that angular
here must be understood as radian ?
Yes, I agree. I'll update the docs for those two functions right away.
/Kristian
-----Oprindelig meddelelse-----
Fra: Even Rouault <even.rouault at spatialys.com>
Sendt: 2. april 2019 12:27
Til: proj at lists.osgeo.org
Cc: Kristian Evers <kreve at sdfe.dk>; a.furieri at lqt.it
Emne: Re: [PROJ] About PROJ.6: Radians or Degrees ?
On mardi 2 avril 2019 08:21:32 CEST Kristian Evers wrote:
> I agree that the documenation of this could be better. Suggestions
> for improvements are appreciated. Pull requests that improve
> the docs are also greatly appreciated :-)
> Your conclusions based on your tests are not exhaustive. Is is
> possible to have proj_create() return degrees instead of radians
> by adding a unitconvert step to a pipeline.
> Similarly,
> proj_create_crs_to_crs() can theoretically return a PJ that outputs
> radians instead of degrees (not sure if it actually is the case currently).
Without adding extra definitions in proj.db, I don't have in mind how radians
could be expected or returned. But if you use EPSG:4807 (NTF (Paris)), you'll
have grads for example.
Normally when using proj_create_crs_to_crs(), if your application uses
coordinates expressed with the units (and axis order...) of the source and
target CRS, you should'nt have to worry about doing any conversion when using
proj_trans[_xxx]() with the PJ* returned by proj_create_crs_to_crs()
If you really need to determine the axis semantics and units, then you need to
chain the following calls:
- proj_get_source_crs() / proj_get_target_crs()
- proj_crs_get_coordinate_system() (if it is a SingleCRS. if it is a
CompoundCRS then you need to extra its component CRS first with
proj_crs_get_sub_crs())
- proj_cs_get_axis_info()
Partial implementation of this (for determining axis swapping) in
https://github.com/pramsey/postgis/blob/
7ecf6839c57a838e2c8540001a3cd35b78a730db/liblwgeom/lwgeom_transform.c#L299
> Use proj_angular_input() [0] and proj_angular_output() [1] to determine
> what a PJ expects and returns.
If another angular unit is expected/returned, those functions will return
false, like in
https://github.com/OSGeo/proj.4/blob/master/test/unit/
proj_angular_io_test.cpp#L76
Even
http://www.spatialys.com
More information about the PROJ mailing list
