[PROJ] Use of EPSG codes in proj_create()
Oliver Eichler oliver.eichler at dspsolutions.de
Tue Apr 2 22:45:23 PDT 2019
>> sounds promising. Will there be an example in the migration guide?
>> Right
>> now this guide is pretty frustrating. It gives you a rough example of
>> something that does not even match the old behavior and the rest is
>> "find out yourself". No documentation in the headers. No obvious link
>> to
>> API documentation on the web page. Yes, I found it by chance using
>> Google.
> Any suggestion on how to make it more accessible ?
Easy ;) "PROJ API Documentation" as top level item in the left hand
menu.
And as a developer using this API I would expect the documentation to be
part of the header files. Don't know why you guys don't like Doxygen.
Cheers
Oliver
More information about the PROJ mailing list
