[PROJ] Use of EPSG codes in proj_create()
Kristian Evers kristianevers at gmail.com
Tue Apr 2 23:19:50 PDT 2019
> On 3 Apr 2019, at 07:45, Oliver Eichler <oliver.eichler at dspsolutions.de> wrote:
>>> sounds promising. Will there be an example in the migration guide? Right
>>> now this guide is pretty frustrating. It gives you a rough example of
>>> something that does not even match the old behavior and the rest is
>>> "find out yourself". No documentation in the headers. No obvious link to
>>> API documentation on the web page. Yes, I found it by chance using
>>> Google.
>> Any suggestion on how to make it more accessible ?
> Easy ;) "PROJ API Documentation" as top level item in the left hand menu.
Yes, this should be done. Easy fix.
> And as a developer using this API I would expect the documentation to be part of the header files. Don't know why you guys don't like Doxygen.
We do in fact use Doxygen. At least for some of the code. The code is documented where it is implemented and not in the header files.
I don’t see this changing anytime soon.
/Kristian
> Cheers
> Oliver
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
