[PROJ] Complete list of unit names?
Martin Desruisseaux martin.desruisseaux at geomatys.com
Mon Apr 8 01:19:53 PDT 2019
Le 08/04/2019 à 10:10, Even Rouault a écrit :
> If it is built from a EPSG code, this will be one of the name in the
> data/sql/unit_of_measure.sql file
In case it may be of interest, it is possible to browse EPSG units
on-line by going on the http://www.epsg-registry.org/ web site, select
"Unit of Measure (UOM)" in the "Type" field, then click the "Search"
button. As of EPSG dataset 9.6.1, there is 86 units.
    Martin
More information about the PROJ mailing list
