[PROJ] some questions about the Barn Raising
Even Rouault even.rouault at spatialys.com
Thu Apr 18 02:25:29 PDT 2019
On mardi 16 avril 2019 19:41:52 CEST Even Rouault wrote:
> Eduardo,
> > I want to promote the initiative "/GDAL Coordinate System Barn Raising"/
> > because in Costa Rica there has recently been a change of CRS - from
> > CRTM05
> > (EPSG 5367) to CR-SIRGAS (EPSG 8906)
> You meant CR-SIRGAS (EPSG *8908*) right ?
> This was a very interesting use case that exhibit a few bugs in PROJ I've
> just fixed per https://github.com/OSGeo/proj.4/pull/1427 (for PROJ 6.1)
I didn't detail the oddity. But the EPSG:8913 transformation (CR05 to CR-
SIRGAS (1)) uses Geographic 3D CRS as source and target CRS for the
transformation, wheras the transformation method is EPSG:9606 method (Position
Vector transformation (geog2D domain)). I got confirmation from IOGP that this
entry is bogus, and will be replaced by a new one in the next release of the
EPSG dataset to use the corresponding Geographic 2D CRS. And that was
apparently the only such erroneous case in the database, so definitely a very
interesting use case :-)
Even
http://www.spatialys.com
More information about the PROJ mailing list
