[PROJ] Correcting map projection errors
Charles Karney charles.karney at sri.com
Thu Apr 25 10:31:10 PDT 2019
On 4/24/19 10:58 PM, Ken Mankoff wrote:
> Hi Charles,
> Thanks for contributing to the discussion. I'm going offline for the
> next 5 weeks and so I can't follow up much more on this, but I'm happy
> to hear you think the current method is probably good enough.
You should verify this!  Take a sampling of rectangles over your map and
compare the area computations:
* projected area with the scale correction,
* area returned by Planimeter,
and check that the discrepancy is small enough for your purposes.
> I'm not tied to proj4 or any specific tool, but prefer to use existing
> user-level tools rather than code my own, even a simple wrapper function
> - so for this reason I would rather run your planimeter tool than access
> the proj function you link to. Unless that function is exposed through
> the proj CLI interface somehow.
No, the proj CLI does not include area calculations.  The geod program
just solves plain the direct and inverse geodesic problems.
More information about the PROJ mailing list
