[PROJ] EPSG:3034 axis ordering
Even Rouault even.rouault at spatialys.com
Tue Apr 30 06:54:30 PDT 2019
On mardi 30 avril 2019 15:17:30 CEST Erik Ravhed wrote:
> Hi all,
> I have a question regarding EPSG:3034 and its axis ordering. According
> to https://www.epsg-registry.org the order of the axes should be ordered
> as northing easting. Looking at the proj4 definition it is defined as
> the following:
> +proj=lcc +lat_1=35 +lat_2=65 +lat_0=52 +lon_0=10 +x_0=4000000 +y_0=2800000
> +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
> Looking at this definition I don't see how I can determine that
> EPSG:3034 should be treated as a northing easting. Shouldn't |+axis=neu|
> be a part of the proj4 definition?
Presumably, but proj strings will remain like that forever at that point of
history, since axis order of projectedCRS was never a concern in PROJ < 6 era,
and a lot of users of those code still wanted easting, northing order whatever
EPSG said.
PROJ 6 is now fully axis aware, so when doing a transformation from ETRS89
lat/long to EPSG:3034, you get:
$ src/projinfo -s EPSG:4258 -t EPSG:3034 -o PROJ
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert
+xy_in=deg +xy_out=rad +step +proj=lcc +lat_0=52 +lon_0=10 +lat_1=35 +lat_2=65
+x_0=4000000 +y_0=2800000 +ellps=GRS80 +step +proj=axisswap +order=2,1
So you have a first axisswap operation to go from input lat,long to internal
long,lat, then the map projection, and then another axisswap operation to go
from te internal easting,northing to final northing,easting
Even
http://www.spatialys.com
More information about the PROJ mailing list
