[PROJ] EPSG:3034 axis ordering
Erik Ravhed erik.ravhed at t-kartor.com
Tue Apr 30 07:12:17 PDT 2019
Thanks for the quick reply and explanation!
Erik
On 4/30/19 3:54 PM, Even Rouault wrote:
> On mardi 30 avril 2019 15:17:30 CEST Erik Ravhed wrote:
>> Hi all,
>> I have a question regarding EPSG:3034 and its axis ordering. According
>> to https://www.epsg-registry.org the order of the axes should be ordered
>> as northing easting. Looking at the proj4 definition it is defined as
>> the following:
>> +proj=lcc +lat_1=35 +lat_2=65 +lat_0=52 +lon_0=10 +x_0=4000000 +y_0=2800000
>> +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
>> Looking at this definition I don't see how I can determine that
>> EPSG:3034 should be treated as a northing easting. Shouldn't |+axis=neu|
>> be a part of the proj4 definition?
> Presumably, but proj strings will remain like that forever at that point of
> history, since axis order of projectedCRS was never a concern in PROJ < 6 era,
> and a lot of users of those code still wanted easting, northing order whatever
> EPSG said.
> PROJ 6 is now fully axis aware, so when doing a transformation from ETRS89
> lat/long to EPSG:3034, you get:
> $ src/projinfo -s EPSG:4258 -t EPSG:3034 -o PROJ
> PROJ string:
> +proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert
> +xy_in=deg +xy_out=rad +step +proj=lcc +lat_0=52 +lon_0=10 +lat_1=35 +lat_2=65
> +x_0=4000000 +y_0=2800000 +ellps=GRS80 +step +proj=axisswap +order=2,1
> So you have a first axisswap operation to go from input lat,long to internal
> long,lat, then the map projection, and then another axisswap operation to go
> from te internal easting,northing to final northing,easting
> Even
More information about the PROJ mailing list
