[PROJ] [Internet] Re: Why is std=gnu89 tested/enabled ?
Dechaux Eric CEN (BCQ STIG) eric.dechaux at gendarmerie.interieur.gouv.fr
Wed Aug 21 05:30:11 PDT 2019
The test suite runs properly, so is the calling application (PostgreSQL
+ PostGIS).
Thanks for the clarification.
Le 21/08/2019 à 14:10, Kristian Evers a écrit :
> No, I don’t think so. Internally PROJ defines some math functions that
> is first introduced with C99. If the build system detects that they
> are available with your compiler the system functions are used
> instead. As far as I remember that is the only difference between
> using C89 and C99 to build PROJ 5.2.0. Try running the test suite, it
> should give you a good indication if it works or not.
> /Kristian
>> On 21 Aug 2019, at 13:55, Dechaux Eric CEN (BCQ STIG)
>> <eric.dechaux at gendarmerie.interieur.gouv.fr
>> <mailto:eric.dechaux at gendarmerie.interieur.gouv.fr>> wrote:
>> Thanks Kristian,
>> On Solaris, NAN is not available with C89. Is there an issue to build
>> proj 5 forcing C99 by replacing -std=c89 to -std=c99 in the Makefile,
>> after configure ?
>> Regards.
>> Le 21/08/2019 à 12:43, Kristian Evers a écrit :
>>> Eric,
>>> A C++11 compatible compiler is only required for PROJ 6 and onwards.
>>> This was introduced with RFC3 [0]. Previous versions was strictly
>>> C89, hence the enforcement of that standard in PROJ 5.2.0.
>>> /Kristian
>>> [0] https://proj.org/community/rfc/rfc-3.html
>>>> On 16 Aug 2019, at 14:57, Dechaux Eric CEN (BCQ STIG)
>>>> Greetings,
>>>> I have been investigating proj 5.2.0 build failure on Solaris 11.3
>>>> for amd64. At some point the build stops on error because of the
>>>> NAN being not declared :
>>>> gcc -DHAVE_CONFIG_H -I.
>>>> -DPROJ_LIB=\"/appli/stig/11.3-20190816-104632/share/proj\"
>>>> -DMUTEX_pthread  -D_FORTIFY_SOURCE=2 -I/usr/include/pcre
>>>> -I/appli/stig/11.3-20190816-104632/include -Wall
>>>> -Wdeclaration-after-statement -Wextra -Winit-self
>>>> -Wunused-parameter -Wmissing-prototypes -Wmissing-declarations
>>>> -Wformat -Werror=format-security -Wno-format-nonliteral
>>>> -Wlogical-op -Wshadow -Werror=vla -Wdeclaration-after-statement
>>>> -Wdate-time -Wfloat-conversion -std=gnu89 -m64 -O2
>>>> -fstack-protector-strong -fpic -fPIC --param=ssp-buffer-size=4
>>>> -I/appli/stig/11.3-20190816-104632/include -DHAVE_C99_MATH=1 -MT
>>>> proj_strtod.o -MD -MP -MF .deps/proj_strtod.Tpo -c -o proj_strtod.o
>>>> proj_strtod.c
>>>> gie.c: In function ‘cart_selftest’:
>>>> gie.c:2008:20: error: ‘NAN’ undeclared (first use in this function)
>>>>      a = proj_coord(NAN, NAN, NAN, NAN);
>>>> gie.c:2008:20: note: each undeclared identifier is reported only
>>>> once for each function it appears in
>>>> make[2]: *** [gie.o] Erreur 1
>>>> As the documentation specify a C and C++11 compiler is required I
>>>> changed the CFLAGS to include -std=gnu11. The build and checks run
>>>> without errror. Solaris 11.3 is bundled with GCC 5.3 with uses
>>>> gnu11 by default for C and there should be no reason to force for
>>>> it on the CFLAGS.
>>>> I noticed the configure script detects and automatically adds
>>>> -std=gnu89 to the CFLAGS :
>>>>     checking whether C compiler accepts -Wdocumentation
>>>> -Wno-documentation-deprecated-sync... no
>>>>     checking if -std=gnu89 can be enabled... yes
>>>>     checking whether C++ compiler accepts -Wunused-private-field... no
>>>> On Solaris this disables the NAN macro as it is C99:
>>>> $ cat test.c
>>>> #include <stdlib.h>
>>>> #include <math.h>
>>>> int main (void) {
>>>>         float f ;
>>>>         f = NAN ;
>>>>         exit (EXIT_SUCCESS) ;
>>>> $ gcc -std=gnu89 test.c
>>>> test.c: In function ‘main’:
>>>> test.c:7:6: error: ‘NAN’ undeclared (first use in this function)
>>>>   f = NAN ;
>>>> test.c:7:6: note: each undeclared identifier is reported only once
>>>> $ gcc -std=gnu99 test.c
>>>> $ gcc -std=gnu11 test.c
>>>> What is the purpose of forcing C standard to gnu89  ?
>>>> Thanks.
>>>> -- Eric
>>>> Ce message �lectronique et tous les fichiers attach�s qu'il
>>>> contient sont confidentiels et destin�s exclusivement � l'usage de
>>>> la personne � laquelle ils sont adress�s. Si vous avez re�u ce
>>>> message par erreur, merci de le retourner � son �metteur. La
>>>> publication, l'usage, la distribution, l'impression ou la copie non
>>>> autoris�e de ce message et des attachements qu'il contient sont
>>>> strictement interdits.
>>>> En cas d'urgence, composez le 17 ou le 112.
>>>> Afin de contribuer au respect de l'environnement, merci de
>>>> n'imprimer cet e-mail qu'en cas de necessite.
>>>> This e-mail and any files transmitted with it are confidential and
>>>> intended solely for the use of the individual to whom it is
>>>> addressed. If you have received this email in error please send it
>>>> back to the person that sent it to you. Unauthorized publication,
>>>> use, dissemination, forwarding, printing or copying of this email
>>>> and its associated attachments is strictly prohibited.
>>>> In case of emergency, dial number 17 or 112.
>>>> To contribute to the environmental protection, please print this
>>>> e-mail only if necessary.
>>>> _______________________________________________
>>>> PROJ mailing list
>>>> PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
>>>> https://lists.osgeo.org/mailman/listinfo/proj
>> <signature.png>
>> Ce message �lectronique et tous les fichiers attach�s qu'il contient
>> sont confidentiels et destin�s exclusivement � l'usage de la personne
>> � laquelle ils sont adress�s. Si vous avez re�u ce message par
>> erreur, merci de le retourner � son �metteur. La publication,
>> l'usage, la distribution, l'impression ou la copie non autoris�e de
>> ce message et des attachements qu'il contient sont strictement interdits.
>> Afin de contribuer au respect de l'environnement, merci de n'imprimer
>> use, dissemination, forwarding, printing or copying of this email and
>> PROJ mailing list
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190821/a73b7b3a/attachment-0001.txt>
More information about the PROJ mailing list
