[PROJ] Proposal for a geodetic deformation model format
Martin Desruisseaux martin.desruisseaux at geomatys.com
Thu Dec 5 11:41:10 PST 2019
Hello Chris
Thanks for your reply.
Le 05/12/2019 à 19:00, Chris Crook a écrit :
> As you rightly say there is also a lot value in a standardisation
> process with OGC, though of course that is a (much much) longer process.
Just for information, from the presentation we had at OGC, it seems that
ESRI wants to go relatively fast too (1~3 years in my understanding).
> On HDF5 vs GeoTIFF.. As you rightly say apart from some details this
> proposal is largely format agnostic. I know the ESRI GGXF initiative
> is now proposing using HDF5, and certainly that could serve as well.
A possible approach could be to put table(s) mapping the document
attributes to CF-Conventions attributes when a match exists (i.e. to
draft what it would looks like if the data were in a HDF5 file). It may
help to compare the formats. But I realize that it would require more
work, this is not a request.
> Curiously I did propose HDF5 as an option for deformation models a
> while ago, but at that time there wasn't much appetite for using it as
> (IIRC) it wasn't so well suited to deploying with online web services.
Its seems that HDF5 viewers exist in JavaScript since 2016 [1], and
other readers are yet more recent [2]. Maybe they were missing at time
of your proposal. But I admit that HDF5 support in browsers is not as
old as GeoTIFF supports.
> (…snip…) I found as I was developing this proposal that there seemed
> to be more advantages to a multiple file implementation. Because
> GeoTIFF provides the nested grid capability the number of files is not
> excessive (unlike the LINZ publication format as individual grids).
> One advantage is that different versions of the deformation model will
> only differ in a few of the component files. Most would be common to
> the versions, so using a multiple file implementation allows these to
> be shared.
Thanks for the insight. Together with Even questions in his previous
email it help me to understand better.
     Regards,
         Martin
[1] https://github.com/HDF-NI
[2] https://github.com/usnistgov/jsfive
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191205/32adfb3b/attachment.html>
More information about the PROJ mailing list
