[PROJ] Proj6 Docs
Even Rouault even.rouault at spatialys.com
Sat Feb 16 10:24:17 PST 2019
Paul,
Answering this question and the one about X/Y order.
Yes PJ objects can be of different kinds and do not all play well with all
functions.
proj_crs_get_coordinate_system(), as the name implies, expects a PJ object of
type CRS, but proj_create_crs_to_crs() returns a PJ object of type Coordinate
Operation / pipeline
So you should call proj_crs_get_coordinate_system() on the result of
proj_create("EPSG:4326") instead.
Or, after the commit I just pushed, you can extract the source CRS from the
pipeline with proj_get_source_crs() (but only if you've created the pipeline
with proj_create_crs_to_crs(). Not if you created it with
proj_create("+proj=pipeline ...") )
Regarding the proj6 docs, they will be online as soon as it is promoted. You
can build them locally with "make html" in the docs/ directory. The output
will be in docs/build/html/
Even
http://www.spatialys.com
More information about the PROJ mailing list
