[PROJ] comparing projstrings
Even Rouault even.rouault at spatialys.com
Tue Jan 1 07:40:01 PST 2019
Idan,
> Is there any importance for the order of the parameters in a projstring CRS
> definition?
For a single step pipeline, no. But starting with PROJ 5, it you use a
proj=pipeline, yes the order of steps matter.
> Is there a function that compares projstrings that takes into consideration
> that two projstrings can be equal even if the strings are not exactly the
> same?
For single-step proj strings and currently released versions, using GDAL with
OSRImportFromProj4() + OSRIsSame() will do
If you use PROJ master, you can equivalently use
proj_create_from_proj_string() + proj_is_equivalent_to(). Note that this will
work as you mentionned only for single-step strings. (For multiple steps, this
will mostly be equivalent to exact string comparisons)
Even
http://www.spatialys.com
More information about the PROJ mailing list
