[PROJ] comparing projstrings
Thomas Knudsen knudsen.thomas at gmail.com
Tue Jan 1 10:00:28 PST 2019
Also remember to take pipeline globals into account: proj=pipeline
ellps=GRS80 step ... step... will set ellps=GRS80 for all steps due to the
definition being put before first step definition
tir. d. 1. jan. 2019 16.40 skrev Even Rouault <even.rouault at spatialys.com>:
> Idan,
> > Is there any importance for the order of the parameters in a projstring
> CRS
> > definition?
> For a single step pipeline, no. But starting with PROJ 5, it you use a
> proj=pipeline, yes the order of steps matter.
> > Is there a function that compares projstrings that takes into
> consideration
> > that two projstrings can be equal even if the strings are not exactly the
> > same?
> For single-step proj strings and currently released versions, using GDAL
> with
> OSRImportFromProj4() + OSRIsSame() will do
> If you use PROJ master, you can equivalently use
> proj_create_from_proj_string() + proj_is_equivalent_to(). Note that this
> will
> work as you mentionned only for single-step strings. (For multiple steps,
> this
> will mostly be equivalent to exact string comparisons)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190101/de7608ba/attachment.html>
More information about the PROJ mailing list
