[PROJ] PROJ4 Version 4.9.3 Need .dll
Idan Miara idan at miara.com
Wed Jan 9 05:49:26 PST 2019
You're welcome.
You could always use depends (http://www.dependencywalker.com/) to know a
DLL's dependencies.
OSGeo4W also downloads for you the dependencies along with the latest
version.
Thus I advise you to use the OSGeo4W installer.
As per your question, the x64 version depends on MSVCR100.DLL, which can be
downloaded also from here:
http://www.norbit.de/osgeo4w/x86_64/release/msvcrt/msvcrt2010/msvcrt2010-1.0.0-1.tar.bz2
(which would be the file that the OSGeo4W installer would download for you)
On Wed, 9 Jan 2019 at 15:38, Wood, Rebekah <
Rebekah.Wood at freshfromflorida.com> wrote:
> You are an angel…Thank you so much.  Do you know if msvcp71.dll and
> msvcr71.dll are used by PROJ and if it is would I need a newer version of
> those files?  These are Microsoft C Runtime library files that are required
> to run several Microsoft and non-Microsoft applications on a Windows system.
> *From:* Idan Miara <idan at miara.com>
> *Sent:* Wednesday, January 09, 2019 8:28 AM
> *To:* Wood, Rebekah <Rebekah.Wood at freshfromflorida.com>
> *Cc:* PROJ <proj at lists.osgeo.org>
> *Subject:* Re: [PROJ] PROJ4 Version 4.9.3 Need .dll
> There you go :)
> 64bit:
> http://www.norbit.de/osgeo4w/x86_64/release/proj/proj4dll/proj4dll-4.9.3-2.tar.bz2
> 32bit:
> http://www.norbit.de/osgeo4w/x86/release/proj/proj4dll/proj4dll-4.9.3-1.tar.bz2
> On Wed, 9 Jan 2019 at 15:24, Wood, Rebekah <
> Is it possible for you to email the .dll for PROJ 4.9.3 to me.  I don’t
> understand why I need to run this OSGeo4W network installer.  I just need
> the one file.
> *Sent:* Wednesday, January 09, 2019 8:14 AM
> Hi,
> You can get the latest Windows binaries for 4.9.3 as well as for 5.2 from
> the OSGeo4W setup:
> https://trac.osgeo.org/osgeo4w/
> Idan
> On Wed, 9 Jan 2019, 15:11 Wood, Rebekah <Rebekah.Wood at freshfromflorida.com
> wrote:
> Good Morning,
> I need the compiled .dll for the highest versioning level of PROJ4 which I
> believe is Version 4.9.3.  Please let me know if this can be provided to
> me.  I have downloaded the source code but am uncomfortable compiling it.
> The directions are not very clear to me.
> Thanks,
> Becky
> Systems Project Consultant
> Florida Forest Service
> Florida Department of Agriculture and Consumer Services
> Office:  (850) 681-5863
> The Conner Building
> 3125 Conner Boulevard Room S-1
> Tallahassee, FL 32399-1650
> www.FreshFromFlorida.com
> Please note that Florida has a broad public records law (Chapter 119,
> Florida Statutes).
> Most written communications to or from state employees are public records
> obtainable
> by the public upon request.  Emails sent to me at this email address may
> be considered
> public and will only be withheld from disclosure if deemed confidential
> pursuant to the
> laws of the State of Florida.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190109/fcdb1d59/attachment.html>
More information about the PROJ mailing list
