[PROJ] PROJ4 Version 4.9.3 Need .dll
jmfluis at gmail.com jmfluis at gmail.com
Wed Jan 9 07:36:01 PST 2019
On a side note. I find that the DependencyWalker is horribly slow. I’m now using this one
https://github.com/lucasg/Dependencies
that is blazingly fast.
Joaquim
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Idan Miara
Sent: Wednesday, January 9, 2019 1:49 PM
To: Wood, Rebekah <Rebekah.Wood at freshfromflorida.com>
Cc: PROJ <proj at lists.osgeo.org>
Subject: Re: [PROJ] PROJ4 Version 4.9.3 Need .dll
You're welcome.
You could always use depends (http://www.dependencywalker.com/) to know a DLL's dependencies.
OSGeo4W also downloads for you the dependencies along with the latest version.
Thus I advise you to use the OSGeo4W installer.
As per your question, the x64 version depends on MSVCR100.DLL, which can be downloaded also from here:
http://www.norbit.de/osgeo4w/x86_64/release/msvcrt/msvcrt2010/msvcrt2010-1.0.0-1.tar.bz2
(which would be the file that the OSGeo4W installer would download for you)
On Wed, 9 Jan 2019 at 15:38, Wood, Rebekah <Rebekah.Wood at freshfromflorida.com <mailto:Rebekah.Wood at freshfromflorida.com> > wrote:
You are an angel…Thank you so much.  Do you know if msvcp71.dll and msvcr71.dll are used by PROJ and if it is would I need a newer version of those files?  These are Microsoft C Runtime library files that are required to run several Microsoft and non-Microsoft applications on a Windows system.
From: Idan Miara <idan at miara.com <mailto:idan at miara.com> >
Sent: Wednesday, January 09, 2019 8:28 AM
To: Wood, Rebekah <Rebekah.Wood at freshfromflorida.com <mailto:Rebekah.Wood at freshfromflorida.com> >
Cc: PROJ <proj at lists.osgeo.org <mailto:proj at lists.osgeo.org> >
There you go :)
64bit:
http://www.norbit.de/osgeo4w/x86_64/release/proj/proj4dll/proj4dll-4.9.3-2.tar.bz2
32bit:
http://www.norbit.de/osgeo4w/x86/release/proj/proj4dll/proj4dll-4.9.3-1.tar.bz2
On Wed, 9 Jan 2019 at 15:24, Wood, Rebekah <Rebekah.Wood at freshfromflorida.com <mailto:Rebekah.Wood at freshfromflorida.com> > wrote:
Is it possible for you to email the .dll for PROJ 4.9.3 to me.  I don’t understand why I need to run this OSGeo4W network installer.  I just need the one file.
Sent: Wednesday, January 09, 2019 8:14 AM
You can get the latest Windows binaries for 4.9.3 as well as for 5.2 from the OSGeo4W setup:
https://trac.osgeo.org/osgeo4w/
Idan
On Wed, 9 Jan 2019, 15:11 Wood, Rebekah <Rebekah.Wood at freshfromflorida.com <mailto:Rebekah.Wood at freshfromflorida.com>  wrote:
Good Morning,
I need the compiled .dll for the highest versioning level of PROJ4 which I believe is Version 4.9.3.  Please let me know if this can be provided to me.  I have downloaded the source code but am uncomfortable compiling it.  The directions are not very clear to me.
Thanks,
Becky
Systems Project Consultant
Florida Forest Service
Florida Department of Agriculture and Consumer Services
Office:  (850) 681-5863
The Conner Building
3125 Conner Boulevard Room S-1
Tallahassee, FL 32399-1650
www.FreshFromFlorida.com <http://www.FreshFromFlorida.com>
Please note that Florida has a broad public records law (Chapter 119, Florida Statutes).
Most written communications to or from state employees are public records obtainable
by the public upon request.  Emails sent to me at this email address may be considered
public and will only be withheld from disclosure if deemed confidential pursuant to the
laws of the State of Florida.
PROJ mailing list
PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190109/1639bfac/attachment-0001.html>
More information about the PROJ mailing list
