[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Howard Butler howard at hobu.co
Thu Nov 7 06:50:30 PST 2019
> On Nov 7, 2019, at 8:15 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> It has been reported that PROJ 6.2.1 (also applies to master) runs super slow
> if used with a too old SQLite version (https://github.com/OSGeo/PROJ/issues/
> 1718). It works fine with SQLite 3.11 (as found on Ubuntu 16.04 for example).
> SQLite 3.11 was released on 2016-02-15, so meets our "older than 2 years"
> rule.
> Hence the following motion
> Require SQLite 3.11 for PROJ master
> +1 Even
> PR implementing this ready in https://github.com/OSGeo/PROJ/pull/1721
> Will apply for PROJ 6.3
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
