[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Howard Butler howard at hobu.co
Thu Nov 7 06:52:48 PST 2019
+0. I'd like to hear from the packagers on this. We're already making life complicated for them, and SQLite is a frequently referenced dependency. Does 3.11 pick up common RHEL/Centos installations? Android/iOS?
Howard
> On Nov 7, 2019, at 8:50 AM, Howard Butler <howard at hobu.co> wrote:
>> On Nov 7, 2019, at 8:15 AM, Even Rouault <even.rouault at spatialys.com> wrote:
>> Hi,
>> It has been reported that PROJ 6.2.1 (also applies to master) runs super slow
>> if used with a too old SQLite version (https://github.com/OSGeo/PROJ/issues/
>> 1718). It works fine with SQLite 3.11 (as found on Ubuntu 16.04 for example).
>> SQLite 3.11 was released on 2016-02-15, so meets our "older than 2 years"
>> rule.
>> Hence the following motion
>> Require SQLite 3.11 for PROJ master
>> +1 Even
>> PR implementing this ready in https://github.com/OSGeo/PROJ/pull/1721
>> Will apply for PROJ 6.3
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
