[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Kristian Evers kreve at sdfe.dk
Thu Nov 7 10:27:59 PST 2019
I am also +1 on this. I am just wondering if 3.11 is the lowest possible
version that is feasible to use with PROJ. From the linked issue I understand
that SQLite 3.8.x is too slow and that it works with 3.11. I take it that 3.11 was
chosen because it was readily available for Even. Would 3.9 or 3.10 work
as well? Or was there a specific change in 3.11 that we know is the one that
makes the difference?
/Kristian
> On 7 Nov 2019, at 18:14, Even Rouault <even.rouault at spatialys.com> wrote:
> On jeudi 7 novembre 2019 17:49:26 CET Thomas Knudsen wrote:
>> +1
>> (convinced by the evidence and reasoning provided by Greg and Bas, although
>> it would be nice if we in any practical way could "suggest", rather than
>> "require" >=3.11)
> No, this is really a functional requirement to get nominal behaviour of the
> library. Otherwise runtime experience will be terrible (it is not like running
> with older sqlite is 10% slower. It is 1 to 2 order of magnitude slower. see
> the ticket) and people will complain. If people really want to run against
> older versions, they can easily change configure.ac/CMakeLists.txt to remove
> the check, but at least they will know that they're doing risky games and
> hopefully they won't complain to community forums that it is slow.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
