[PROJ] "Trustworthiness" of vertical transformations
Nyall Dawson nyall.dawson at gmail.com
Mon Nov 25 16:26:55 PST 2019
Hi list,
I've seen a lot of activity on the PROJ repo lately relating to
vertical datum transformations. Coming from zero knowledge about the
world of vertical transformations... if I setup a simple
transformation between two proj CRS objects created using auth/id
codes, and transform a 3d point using proj_trans_generic... how
"trustworthy" is the resultant z value?
I've seen some examples (e.g in
https://github.com/OSGeo/PROJ/issues/1743) which use a
"EPSG:26911+5703" type construct, which leads me to believe that the
world of vertical transformations is not so straightforward! Any tips
to give a newbie entering this world to avoid the inevitable pitfalls
which await?
Cheers,
Nyall
More information about the PROJ mailing list
