[PROJ] "Trustworthiness" of vertical transformations
Kristian Evers kreve at sdfe.dk
Tue Nov 26 02:52:07 PST 2019
Nyall,
You are indeed correct in assuming that the world of vertical
transformations isn't always straight forward. I think the best
tip I can give you is to consult the accuracy of the transformation
as reported by PROJ. In the example Even has used in the issue
that you link to it is 0.35 m. In other cases it will be "unknown accuracy"
if there is not enough information available about a given transformation.
Ultimately the accuracies are reported by the local geodetic authorities
so in general I would just trust those.
You can get the transformation accuracy using the API function
proj_coordoperation_get_accuracy(). I think it would be cool if
information about transformation accuracy where readily available in
software like QGIS (nudge, nudge :-))
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Nyall Dawson
Sent: 26. november 2019 01:27
To: PROJ <proj at lists.osgeo.org>
Subject: [PROJ] "Trustworthiness" of vertical transformations
Hi list,
I've seen a lot of activity on the PROJ repo lately relating to
vertical datum transformations. Coming from zero knowledge about the
world of vertical transformations... if I setup a simple
transformation between two proj CRS objects created using auth/id
codes, and transform a 3d point using proj_trans_generic... how
"trustworthy" is the resultant z value?
I've seen some examples (e.g in
https://github.com/OSGeo/PROJ/issues/1743) which use a
"EPSG:26911+5703" type construct, which leads me to believe that the
world of vertical transformations is not so straightforward! Any tips
to give a newbie entering this world to avoid the inevitable pitfalls
which await?
Cheers,
Nyall
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
