[PROJ] "Trustworthiness" of vertical transformations
Even Rouault even.rouault at spatialys.com
Tue Nov 26 04:17:51 PST 2019
Nyall,
> I've seen a lot of activity on the PROJ repo lately relating to
> vertical datum transformations. Coming from zero knowledge about the
> world of vertical transformations... if I setup a simple
> transformation between two proj CRS objects created using auth/id
> codes, and transform a 3d point using proj_trans_generic... how
> "trustworthy" is the resultant z value?
If those are just projected CRS or geographic 2D CRS, the resultant z value
will be unchanged. To have some "hope" that you get a change in z value, you
must work with either a CompoundCRS or a Geographic 3D CRS.
> I've seen some examples (e.g in
> https://github.com/OSGeo/PROJ/issues/1743) which use a
> "EPSG:26911+5703" type construct,
This is a special syntax inherited from GDAL to build a compound CRS from a
horizontal CRS (geographic or vertical) + a vertical CRS.
Otherwise the EPSG dataset includes a few coded compound CRS:
https://github.com/OSGeo/PROJ/blob/master/data/sql/compound_crs.sql
So you can use EPSG:3901 to get "KKJ / Finland Uniform Coordinate System + N60
height" directly, instead of EPSG:2393+5717
There's also a more official one coming from a OGC white paper, that you can
see on https://proj.org/apps/projinfo.html :
urn:ogc:def:crs,crs:EPSG::2393,crs:EPSG::5717
> which leads me to believe that the
> world of vertical transformations is not so straightforward!
Indeed it is not. It is what has required the most tunings the last weeks/
months in PROJ. Computing those transformations is also expensive timewise
speaking, because there are both horizontal and vertical transformations to
consider (and as described in https://github.com/OSGeo/PROJ/issues/1743 , if
there's no registered transformation between the vertical CRS and the source
or target geographic 3D CRS, then PROJ researches all the vertical CRS to
whatever_geographic_3D_CRS is registered, and then computes the horizontal
transformation between those whatever_geographic_3D_CRS and the source and
target CRS (*)). Timings of several hundred of milliseconds in
createOperations() are not uncommon, so you need to make sure to keep the
result cached. Execution of pipelines (coordinate reprojection) then runs as
decently as possible.
I've especially worked on improving the results of CompoundCRS <--> Geographic
3D CRS transformations. I'm pretty sure CompoundCRS <--> CompoundCRS would
also require some additional love.
One of the practical difficulties is that if you work with 'exotic' vertical
CRS, there will be no registered transformation between them and a (the)
Geographic 3D CRS, so you'll get a no change in the Z value.
Even
(*) I've a document in the works describing most of the logic behind
createOperations(), but it takes a loooong time to write, as everytime I try
to find an example to illustrate my theory, I find something to improve in the
code :-)
http://www.spatialys.com
More information about the PROJ mailing list
