[PROJ] (Angular/Linear/Scale) speed in C++ API
Martin Desruisseaux martin.desruisseaux at geomatys.com
Wed Nov 27 14:54:50 PST 2019
Hello
The C++ API defines the following enumeration:
    osgeo::proj::common::UnitOfMeasure::Type
With the following values:
    UNKNOWN, NONE, ANGULAR, LINEAR, SCALE, TIME, PARAMETRIC
The METRE unit for instance is of type LINEAR, which is fine. But I find
the following more surprising:
  * METRE_PER_YEAR declared of type LINEAR
  * ARC_SECOND_PER_YEAR declared of type ANGULAR
  * PPM_PER_YEAR declared of type SCALE
I do not see an API for declaring that above units are rates of change
(speed, angular velocity, etc.) rather than classic linear or angular
units. Shouldn't the API contain something for that?
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191127/1745583a/attachment.html>
More information about the PROJ mailing list
