[PROJ] Vector/SIMD acceleration
Even Rouault even.rouault at spatialys.com
Fri Apr 17 05:45:28 PDT 2020
> is this correctly understood?
Yes, I think so. For example, if you have for a given function an
implementation for 4-double and the default one for 1-double,
if you process 14 points, PROJ would call 3 times the 4-double
one and 2 times the 1-double one.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200417/4e5a3850/attachment.html>
More information about the PROJ mailing list
