[PROJ] Adding new projection to Proj4
Kristian Evers kreve at sdfe.dk
Mon Feb 17 02:29:26 PST 2020
Alessandro,
It sounds like this is a good candidate for a new projection in PROJ. Unfortunately I can't access the paper so I can't comment on the details. How is the ground track oblique cassini different from the landsat equivalent?
If you want to add the projection to PROJ I suggest you add a pull request with your implementation. Since you already have written the code this shouldn't be a big task. Here's a previous pull request to get an idea of where to start: https://github.com/OSGeo/PROJ/pull/1133
/Kristian
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Alessandro Burini
Sent: 16. februar 2020 17:07
To: Jeff McKenna <jmckenna at gatewaygeomatics.com>; proj at lists.osgeo.org
Subject: Re: [PROJ] Adding new projection to Proj4
Dear Jeff,
I confirm Martin's interpretation. The Ground Track Oblique Cassini is a new projection method which we would like to have it included in proj4, as done for the landsat projection (https://proj.org/operations/projections/lsat.html). Is this something that can be done?
Alessandro
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
From: Jeff McKenna <jmckenna at gatewaygeomatics.com<mailto:jmckenna at gatewaygeomatics.com>>
Date: 16/02/2020 15:50 (GMT+01:00)
To: proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>
ok thanks for clarifying Martin.  -jeff
On 2020-02-16 9:52 a.m., Martin Desruisseaux wrote:
> I think Alessandro was proposing to add a new "projection method" (i.e.
> another set of mathematical formulas for doing the projection). This is
> a different work than assigning an EPSG code, which is more about
> setting parameter values to use with pre-existing formulas. If this is
> the case, then Alessandro's proposal and EPSG change request would be
> orthogonal tasks.
>      Martin
> Le 16/02/2020 à 13:41, Jeff McKenna a écrit :
>> Hi Alessandro,
>> A new projection can be added into the EPSG registry by filing a
>> change request at: http://www.epsg.org/EPSGDataset/Makechangerequest.aspx
>> I have went through that process several times now, to add a new
>> projection into EPSG, that is then automatically leveraged by software
>> projects, such as PROJ.  Of course it takes time, first for the EPSG
>> committee to review your request, and then also for the new projection
>> to propagate to all software projects.
>> -jeff
> PROJ mailing list
> PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/proj
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
PROJ mailing list
Any email message from EUMETSAT is sent in good faith but shall neither be binding nor construed as constituting a commitment by EUMETSAT, except where provided for in a written agreement or contract or if explicitly stated in the email. Please note that any views or opinions presented in this email are solely those of the sender and do not necessarily represent those of EUMETSAT. This message and any attachments are intended for the sole use of the addressee(s) and may contain confidential and privileged information. Any unauthorised use, disclosure, dissemination or distribution (in whole or in part) of its contents is not permitted. If you received this message in error, please notify the sender and delete it from your system.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200217/c5dd343f/attachment.html>
More information about the PROJ mailing list
