[PROJ] Patterson projection - supported?
Nyall Dawson nyall.dawson at gmail.com
Thu Feb 20 14:20:59 PST 2020
On Fri, 21 Feb 2020 at 05:28, Even Rouault <even.rouault at spatialys.com> wrote:
> Nyall,
> > Does this mean that:
> > a. converting the coordinate operation between EPSG:4326 and
> > ESRI:54079 to a **proj** string is not supported
> > b. creating a coordinate operation for this transform isn't possible at all?
> Yes to both. They are strongly related.
> The "metadata" part of PROJ lacks currently the mapping between the WKT
> representation of this projection and a corresponding PROJ string. Grepping
> for PROJ_WKT2_NAME_METHOD_ECKERT_I / eck1 in the source tree could likely
> serve as inspiration to find the various locations to patch.
> Regarding export to PROJ.4 strings of a CRS definition using this projection
> (to be opposed to building coordinate operation PROJ strings), we should
> probably not do it, because it wouldn't be recognized by the GDAL < 3
> ecosystem.
Perfect -- thanks for the pointers!
Nyall
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
More information about the PROJ mailing list
