[PROJ] Check if a definition if a cartographic projection
José Luis García Pallero jgpallero at gmail.com
Fri Feb 21 03:39:14 PST 2020
Hello:
I'm porting an old PROJ4 code for strictly cartographic projections
(forward and inverse steps) to version 6 and I'm a bit confused about
the definition. I see that I must substitute the old pj_fwd() and
pj_inv() by theproj_trans() function, where I set the forward or
inverse step via the PJ_DIRECTION input argument. My questions are:
1. Is it possible (has PROJ6 any function or other method) to check
the definition in order to guarantee it is strictly a cartographic
projection?
2. Must be the geodesic coordinates for the forward cartographic
problem always radians?
On the other hand, I can read in https://proj.org/operations/index.html
Projections are purely cartographic mappings of the sphere onto the plane
But PROJ also works in the ellipsoid, so I suppose it is a mistake
Best regards
(o<
V_/_
Use Debian GNU/Linux and enjoy!
More information about the PROJ mailing list
