[PROJ] Finnish KKJ with triangle-wise affine transformation
Even Rouault even.rouault at spatialys.com
Wed Jun 17 04:05:27 PDT 2020
Oskari,
> In many places we still need to support the old KKJ (EPSG:2393) system. The
> National Land Survey of Finland (Maanmittauslaitos) provides a TIN network
> and affine transformation for each triangle for converting between
> ETRS-TM35FIN and KKJ. This is the preferred and most accurate way to
> convert to and from KKJ. More information and the plain text data files can
> be found from NLS website though only in Finnish but you should be able to
> get the idea
> https://www.maanmittauslaitos.fi/kartat-ja-paikkatieto/asiantuntevalle-kayt
> tajalle/koordinaattimuunnokset
> My question is, is this kind of transformation something that could be
> implemented inside PROJ at some point in the future? I don't know if this
> kind of thing is used anywhere else so it might be that this has very
> little use outside of Finland.
I'm currently working with National Land Survey of Finland to bring those transformations
into PROJ. So stay tuned. Should come in coming weeks / months. Triangulation-based
transformations are likely of interest in other cases too as a number of grid-based
transformations come initially from triangulations.
> If this isn't viable, are there any plans about plugin support for PROJ? It
> would be cool to be able to implement custom steps and represent them as
> part of the normal PROJ pipeline to implement special needs :-)
I can see pros & cons to a plugin approach. From a community point of view, plugins tend to
"isolate" people. Sometimes what one thinks to be a custom need can be useful for others.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200617/7f3c4321/attachment.html>
More information about the PROJ mailing list
