[PROJ] Finnish KKJ with triangle-wise affine transformation
Oskari Timperi oskari.timperi at novatron.fi
Wed Jun 17 05:17:59 PDT 2020
Hi Even,
You working with NLS sounds really wonderful! This is great news :-)
Is there somewhere I could follow progress on this? Is there any way I could help to make this happen?
I agree with your comment about plugins. But still, sometimes they would be very handy. :-)
- Oskari
Sent: keskiviikko 17. kesäkuuta 2020 14.05
To: proj at lists.osgeo.org
Cc: Oskari Timperi <oskari.timperi at novatron.fi>
Subject: Re: [PROJ] Finnish KKJ with triangle-wise affine transformation
Oskari,
> In many places we still need to support the old KKJ (EPSG:2393) system. The
> National Land Survey of Finland (Maanmittauslaitos) provides a TIN network
> and affine transformation for each triangle for converting between
> ETRS-TM35FIN and KKJ. This is the preferred and most accurate way to
> convert to and from KKJ. More information and the plain text data files can
> be found from NLS website though only in Finnish but you should be able to
> get the idea
> https://www.maanmittauslaitos.fi/kartat-ja-paikkatieto/asiantuntevalle-kayt
> tajalle/koordinaattimuunnokset
> My question is, is this kind of transformation something that could be
> implemented inside PROJ at some point in the future? I don't know if this
> kind of thing is used anywhere else so it might be that this has very
> little use outside of Finland.
I'm currently working with National Land Survey of Finland to bring those transformations into PROJ. So stay tuned. Should come in coming weeks / months. Triangulation-based transformations are likely of interest in other cases too as a number of grid-based transformations come initially from triangulations.
> If this isn't viable, are there any plans about plugin support for PROJ? It
> would be cool to be able to implement custom steps and represent them as
> part of the normal PROJ pipeline to implement special needs :-)
I can see pros & cons to a plugin approach. From a community point of view, plugins tend to "isolate" people. Sometimes what one thinks to be a custom need can be useful for others.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200617/4da9240f/attachment-0001.html>
More information about the PROJ mailing list
