[PROJ] Is DERIVEDPROJCRS implemented?
Even Rouault even.rouault at spatialys.com
Fri Mar 13 00:33:37 PDT 2020
Grabriel,
"Works" for me, in the meaning that
projinfo @derivedprojcrs_wkt.txt
outputs the WKT after ingestion & re-export
However PROJ won't be able to do currently something really useful with it,
namely to use it to perform coordinate transformations, because it doesn't
implement yet the "P6 (I = J-90°) seismic bin grid transformation" method.
The affine transformation is probably the only method it currently implements
that can be used with derived projected CRS.
Even
http://www.spatialys.com
More information about the PROJ mailing list
