[PROJ] Is DERIVEDPROJCRS implemented?
Gabriel De Luca pablogabrieldeluca at gmail.com
Fri Mar 13 02:09:52 PDT 2020
Hi Even,
  I was trying to paste the string in the command shell,
  I am seeing now that projinfo @derivedprojcrs_wkt.txt returns the same
WKT.
 I will try to create it with an affine transformation method.
Thank you very much,
Gabriel
El vie., 13 de mar. de 2020 a la(s) 04:33, Even Rouault (
even.rouault at spatialys.com) escribió:
> Grabriel,
> "Works" for me, in the meaning that
> outputs the WKT after ingestion & re-export
> However PROJ won't be able to do currently something really useful with
> it,
> namely to use it to perform coordinate transformations, because it doesn't
> implement yet the "P6 (I = J-90°) seismic bin grid transformation" method.
> The affine transformation is probably the only method it currently
> implements
> that can be used with derived projected CRS.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200313/bc83b4ad/attachment.html>
More information about the PROJ mailing list
