[PROJ] Calling for 7.0.1 release
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Mar 24 09:13:44 PDT 2020
On 3/24/20 5:01 PM, Devrim Gündüz wrote:
> I'm very excited to push Proj 7.0 to the community repos, so that people can
> benefit from the new features -- but then there is that build failure. I would
> not pester you if it was a Fedora 31 or RHEL 6 issue, but RHEL 7 is still very
> widely used.
The problem with RHEL 7 is that is was released in 2014 around the same
time as Ubuntu trusty which is EOL since 2019.
While RHEL 7 is still widely used, partially because you cannot easily
upgrade running systems to RHEL 8, its packages are quite old by now.
Packaging recent upstream releases on LTS distribution tends to have
these problems, and it's not shame to conclude that those recent
upstream releases cannot reasonably be provided on those LTS distributions.
We see this in UbuntuGIS for example too, it's becoming increasingly
difficult to backports geospatial packages to xenial (released in 2016),
QGIS being a prime example.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200324/dd44ad15/attachment.sig>
More information about the PROJ mailing list
