[PROJ] Calling for 7.0.1 release
    Even Rouault
    even.rouault at spatialys.com
    Wed Mar 25 03:47:28 PDT 2020
On mardi 24 mars 2020 20:41:09 CET Devrim Gündüz wrote:
> Hi,
> On Tue, 2020-03-24 at 17:05 +0100, Sebastiaan Couwenberg wrote:
> > Then I don't really see how a 7.0.1 release is going to help unless you
> > don't retool the sources.
> I won't patch configure.ac. Is that an enough reason?
Sorry if I got lost a bit in the arguments but why, as an interim workaround,
not create a tarball generated on something more recent than RHEL 7 with a
modern tooling chain, and use that to build on RHEL 7 ?
Even
http://www.spatialys.com
More information about the PROJ
