[PROJ] ct2 format to GTG
Kristian Evers kreve at sdfe.dk
Mon May 4 03:32:16 PDT 2020
Hi Dalia
First of all, PROJ 7 can read ct2 files so you don't have to convert them. But of course the GTG is a better format so I would encourage you to do so. What files are you trying to convert? All the grid files that you have previously submitted to proj-datumgrid have all been converted to GTG as you can see here: https://github.com/OSGeo/PROJ-data/tree/master/is_lmi
/Kristian
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Dalia Prizginiene
Sent: 4. maj 2020 12:13
To: proj at lists.osgeo.org
Subject: [PROJ] ct2 format to GTG
Hello,
For Proj7 all grids must be transformed to GTG format. We have two grids in .ct2 format
But I can not find a script in PROJ-data/grid_tools  for ct2 to GTG transformation. Could you give some suggestions on this ?
Með kveðju/ Best regards
Dalia
Dalia Prizginiene
Landmælingar Íslands /  National Land Survey of Iceland
Mælingaverkfræðingur / GNSS Processing
Stillholt 16 - 18, 300 Akranes, +354 430 9006
www.lmi.is<http://www.lmi.is/> / Facebook<https://www.facebook.com/landmaelingar.islands?fref=ts> / Um meðferð tölvupósts / Disclaimer<http://www.lmi.is/landmaelingar-islands/medferd-tolvuposts/>
Hugið að umhverfinu áður en prentað er
Please consider the environment before printing
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200504/2d4df2c2/attachment.html>
More information about the PROJ mailing list
